V&H Shortshots&V&H Fuel Pak
So ups will be delivering my short shots today,already have the fuelpac now want to find out which breather would be best to get best performance out of my 2013 Iron 883 with 1500 miles on it so far,and should I wait to put pipes on to tune with fuel PAC or should I tune for the pipes for now because it may take a few weeks to get the AC thanks for any suggestions
V&H Fuelpak cannot change timing or O2. It can only change fuel which makes it a very limited tuner. IED's would probably be a better choice as they only changes fuel also and they don't need to be tuned. AFR should remain rather constant. PowerVision is probably the ultimate tuner out there if you're looking for a complete stage one. But it's $500. Tuning a bike to nearly full potential is never very cheap. My PCIII plus Dyno was about $800. At that price, a $500 tuner with autotune capabilities is not a bad price considering what you get.
-Beer
-Beer
So Beer,should I just get rid of the fuel PAC and get a power vision tuner,want to get the most out of my engine with a stage one upgrade so if I need to save more money I will,also what air cleaner would be a good choice for what I want to do? I do want to keep the short shots though,while I am saving money for the PV and AC,I can still run with the shorts shots with no worries?Thanks
Received 4,225 Likes
The Outlaw HiFlow 587 A/C System out-performs almost every A/C available.
If you are going to keep the fuel-pak, does not really matter if you install now or later, it only adjusts the AFR in open loop, and it is not lean there anyway.
The PowerVision from Fuelmoto is hard to beat for a performance tune.
Lots of styles to choose from-
__________________
Win Up to $350.00 Cash from DK Custom This Month, Click HERE to see How!
DKCustomProducts.com
As for an a/c, I prefer the Air Hammer from Hammer Performance. It's all billet aluminum with a large K&N filter that is adequate for up to low or mid 90's HP according to Hammer's dyno testing. DK Custom also makes a fine a/c as seen in post above, just depends on taste. There are a lot of adequate a/c's out there. If you want to keep your stock cover, I'd go with an Air Hammer for about $150. The Air Hammer requires an external breather which some people don't like cuz you have to do something about the blow-by that exits the crank case.
Blow-by is misty oily air that vents from the heads and in stock form it's routed into the air cleaner to be burnt in the combustion chamber. I mentioned that only because some people don't like dealing with the blow-by. In my pic you can see a fuel hose coming from the bottom of the a/c, that hose leads to the bottom of the bike to route the blow-by under the frame. You can also see the horseshoe breather that the hose is connected to just above the a/c. There are other ways to deal with the blow-by besides using a fuel hose but to me that's the most straight forward method. The horseshoe breather is about $30 plus the cost of the fuel hose. There are other aftermarket a/c's that don't use a separate breather if that's important to you. My a/c is the naked Air Hammer in pic below for $220. It's a little bulky but I like it.
Watch the DK Custom video above, it will show you more breather options and the video touches on why you don't want dirty blow-by in your engine. You'll also see all of their nice a/c's.
I have the exact same set up you are doing bud. I found out later that the Fuel Pak only adjusts fuel and not your oxygen. However since the fuel Pak allows you to still have your exhaust O2 sensors plugged in, the o2 sensors will automatically adjust for better air flow. That's what the Harley Mechanic told me anyway. I did recently change to the Power Commander V, but only because I had to since I got the 1250 kit. Hope this helps.
