883R/1200S Fork Spring Install Oil Info needed
I have a 2000 Dyna Superglide Sport which has the Sportster 1200S/883R 39mm Compression/Rebound/Preload adjustable legs on it.
I searched the Race Tech site and determined that i need the .95KG springs. I am hoping that someone here has done this job before and can shed some light on the process. Information such as oil weight,rider weight,KG springs used, oil height, and any special notes that could be helpful in the disassembly rebuild process would be helpful.
I have installed springs in a set of 49mm Showas on my dual sport DRz 400 before. The way the damper attatches to the top cap looks different than my DRZ was.
