KB piston Problem/ Question
(1999 sportster)
So my bike was smoking heavily i pulled the plugs and saw that the rear cylinder plug was all oilly like badly so i pulled cylinder to see that the oil rings at the bottom were over lapped and was letting the oil rush up towards the valve area making it all chard. So i moved the rings around and it looks better and is sealing properly i hope! before i put the cylinder on i was wondering weither i should replace the rings? or just leave the ones onn that are on it now. The pistons and rings are not even a month old and no more than 100 miles on it. There is no score marks on the cylinder or piston, and the rings arent bent or chewed.
(Pistons KB272 .020)
I think it would be fine. Just make sure to orient all the ring gaps per instructions and you should be good to go. I'm pretty sure your FSM shows how to align them, and hammer's website has a great diagram of where the ring gaps should be positioned.
Is the front cylinder okay, as far as ring position?
Good luck.
John
Good luck.
John
Good luck.
John
Good luck.
John
Dustin Miller
07-28-2014 09:58 PM
