2 into 1 exhaust ?
Old 04-29-2013, 12:22 PM
bayoucolonel's Avatar
bayoucolonel
bayoucolonel is offline
Stage II
I am pretty confident I can change out the exhaust on my bike, but, do ya'll think any other adjustments would need to be made? i.e. idle speed, carb adjustment......those things are past my ability. I am running stock now. thanks,
Old 04-29-2013, 01:49 PM
EasternPC_CustomerService's Avatar
EasternPC_CustomerService is offline
Former Sponsor
Def a great exhaust but if your not going to run the heat shield even tho they are tine you will see the pipes turn gold from the heat. Looking for one give us a ring 2 into 1 offer great sound but even better performance and back pressure.
Old 04-29-2013, 02:44 PM
backplay's Avatar
backplay
backplay is offline
Originally Posted by mrfikser
am I missing something...it looks like they are all for rubber mount motors
My mistake, I had forgotten your year... sorry dude..
Old 04-29-2013, 09:03 PM
Simpatico's Avatar
Simpatico
Simpatico is offline
I think any time you mess with back pressure you have to re-adjust carbs or re-map FI. That's why they run like crap when the flap is closed. They were probably set up for the flap being opened.
Old 05-03-2013, 03:29 AM
Simpatico's Avatar
Simpatico
I see that Patriot raised the prices $50. no longer $295. & $395.
Old 05-03-2013, 05:50 AM
rickss69's Avatar
rickss69
rickss69 is offline
Pity...they saw the sales rising and decided to raise the price. Best pipe on the dyno, but if they go too far the sales will dip...not the best looking 2-1 exhaust out there if you know what I mean.
Old 05-11-2013, 07:11 PM
Simpatico's Avatar
Simpatico
rickss69, for sure they aren't the best looking pipes out there, but performance wise they rank pretty high.
Old 05-11-2013, 08:30 PM
rickss69's Avatar
rickss69
rickss69 is offline
Nothing has beat them on Hammer's dyno to date...still ugly lol. Finally got around to putting them on the '07 and was surprised how quiet they are vs the ShortShots they replaced. With the butterfly fully opened you can take this one anywhere...only barks when the throttle is rapped and even then it is quieter than the D&D Bobcat.
Old 07-23-2013, 07:06 PM
1200R05's Avatar
1200R05
1200R05 is offline
Stage IV
Originally Posted by jlp29
Changing the valve takes maybe a minute or two. I saw one where a guy replaced the wire with a metal strap and added a wingnut so he could open/close the valve quickly and with no tools
After the you tube video from rickss69 at the end of this thread, there will be some other videos come up...the one with a 883 nightster shows the metal strap and wingnut conversion.
Old 07-23-2013, 07:18 PM
1200R05's Avatar
1200R05
1200R05 is offline
Stage IV
Originally Posted by jbc1200
I run one on my 1200C and have been playing with the flapper recently. The bike runs much better with it fully open and pretty much like total crap with it closed. There is a long thread on XLForum with dyno tests showing how horrible the pipe does with the flapper closed.
I imagine it would be fine as a short use solution to get out of parking garages or whatever. I've read where a couple guys have used generic choke cables to make the flapper adjustable on the fly.
One thing I've struggled with is that the closer exit of the pipe makes it drone BAD inside my full-face helmet. Worse than the Samson straight pipes I had on previously. Enough that I ordered a Bell 500 to try out since it is not loud at all with my 1/2 helmet.
The pipe is all stainless steel, so it will turn gold after running for a bit. Here is mine after a month.
Nice looking Sportster JBC. I have the Patriot Defenders also, but not installed. I have an 05 1200R and am curious if you had to rejet your carb? Never having done this before, I'm not sure how to go about it...I have seen jet kits in the J and P catolog, but there are upwards of $90 (dyno jet), Is there a cheaper way to go? Also, did you use new exhaust port gaskets? I've had people tell me both ways...just don't want to start a project and have my bike down for a week..Thanks for any help and much appreciated.
Littleredcrate
02-23-2017 08:58 AM
coastie743
03-04-2014 09:49 AM
SwiftyBKells
07-26-2013 01:51 PM
RF99Dyna
06-29-2010 09:35 PM
Big Twi$t
12-30-2007 11:36 PM
Quick Reply: 2 into 1 exhaust ?
