yes nightster has the 3.3 gallon . i forgot what i had on bike . i had other tanks in my shop , LOL !!! so i asking how much cost to go from 3.3 to 4.5 . much a difference for the cost ??? i got a stock seat & a dual seat . thanks
Having a hard time understanding why you and others think you need some type of "kit" to swap gas tanks. I have gone back and forth many times with different size tanks on a '07...you already have everything you need to do the swap. Just transfer the fuel pump out of your existing tank and put it in the new tank. All the existing mounting hardware is the same for all tanks.
When you switched out your tanks, were they raw tanks when purchased and if so, did you have any problems etching them before sealing them? We have etched the tank two times and there is still rust that we can't get out of the seam where it was welded together. Any suggestions on how to get it out? Thank you.
