Stripped Pinch Bolt
I don't know what else to do. It is in SO TIGHT...the head is stripped, i tried grabit but my drill isn't powerful enough to pull it out. I don't know what else i can do. My whole front end it apart and i'll i need is to get that last pinch bolt loose to finish the job
How about posting a photo so we can better advise?
How about a bolt/screw extractor? http://www.canadiantire.ca/AST/brows....jsp?locale=en
That might help, but only after you drill the head. Left-hand drill bit is your best bet atm...a little heat at the same time might help.
I swear i am never going to touch this bike AGAIN. So i finally got the two bolts out, put everything back together, install the front wheel and it spins fine, go to put the caliper on and the wheel no longer spins. I am figuring the bigger spacer goes on the rotor side and the smaller on the other. I am seriously wasting a beautiful day on something i thought would take 30mins to do and im getting really fed up. What could be wrong? YES I DO have a manual.
