First went around the block, brought it in a checked everything out then took it on a 70 mile trip and no issues. Thanks for the all the help...i was going nuts there for a little while
Usually if the Caliper is lubed. at the two points that hold it from the Disc.. Never put lube close to the Disc or Pads. Like the Manual says it could cause Death.. Make sure the Piston is clean where it retracts In the Caliper. Dirty piston can cause the Pad not to retract all the way..
