so sissy bar docking hardware
You shouldn't need to mess with your shocks or lights.
Use blue Loctite. Do one bolt at a time, a little loose at first. Then, set your sissy bar in place to align everything and torque to spec. Verify tire to bolt clearance.
Pic from:
http://www.harley-davidson.com/en_US...ts/-J02896.pdf
Pic from:
The clip secures itself via the bend at the bottom. You'll need to hold it to re-thread the bolt into it. I was able to barely squeeze my hand in there, iirc. There's another piece of hardware under there that's a fender support. That's why I said do one bolt at a time. You don't want the entire assembly under the fender to come apart. I probably used an Allen-wrench style torx tool to get to the bolt head next to the light and/or removed the lense to gain clearance. It looks like if the lense was removed, you could use a 6" extension so your ratchet falls towards the outboard side of the light housing. I used some bungee-nut bolts I made for re-assembly and they require only a standard wrench. They're great for securing a pack.
Thread for bungee bolts. Post #11. I made a set in chrome and had a set powder coated black. I wound up liking the chrome:
https://www.hdforums.com/forum/sport...ked-bolts.html
8super2glide
07-31-2011 09:17 PM
