replacing handlebars
Getting ready to replace my handlebars on my 2000 XL. Is there a connector for the wiring that runs through the bars that I don't see or do I just simply cut and splice the wires? The service manuel does not say anything about this that I can find.
If your bars are in stock condition, there is not a connector inside the bars. There is a plug/connector under the tank and then a connection inside the housings (blinkers/horn/ignition/etc). When I changed my bars I bought a plug/play extension piece and didn't have to splice any wires. However, I don't think that will work if you plan on trying to run the wires internally on your new bars because the plug won't fit through the bars- you'll have to run bare wires and splice them.
