Wire wrap?
Old 04-09-2013 | 09:15 AM
86Apes's Avatar
86Apes
5th Gear
Default Wire wrap?
I put 16" apes on my sportster, love it! I want to clean up the look for the electrical wiring from the top down to the forks on my new bars (already did braided for the throttle and clutch cable. My plan was to put the flex conduit over the wires to bring them together, now I'm looking for something to wrap the conduit with. The only thing I have found in the auto parts store is the foil 'chrome' duct tape. I'm afraid that will look like crap though. Any suggestions? Thanks!
Old 04-09-2013 | 02:23 PM
DallasSportster's Avatar
DallasSportster
I would suggest shrink wrap, but you will have to disconnect the wires to slide it on. Why not internally wire the bars so you have no wires on the outside?
Old 04-09-2013 | 02:36 PM
bmxatv's Avatar
bmxatv
What he said. If you're gonna cut the wires anyway to slip the shrink tubing on might as well run them internal. Of course your bars need to be drilled and dimpled if you're running stock Hd controls. Good luck.
Old 04-09-2013 | 06:47 PM
elfnyc's Avatar
elfnyc
cheap azs mod for diy braided cables
get to home depot or such and get braided water line hose
eastman ice maker water line to be exact ---
cut the ends off
and slide the braided line off the water line -
remove your lines or whatever u wanna cover
tape the ends to hold it in place then heat shrink ends over the tape you placed
instant cables
A dissected stainless steel braided ice maker line set.
Cost $20.02 out the door for 20 feet.
IMO, the 3/8" braid would be perfect for things like spark plug wires, vacuum hoses, fuel lines, clutch/brake cable, etc..
but u can also buy larger diameter lines for bigger projects
just 5 or 10 minutes a line an u have custom braided lines
Old 04-09-2013 | 08:05 PM
tripn88's Avatar
tripn88
Holy **** that's a good idea lol
Old 04-09-2013 | 08:10 PM
elfnyc's Avatar
elfnyc
and cheap
Old 04-09-2013 | 08:11 PM
elfnyc's Avatar
elfnyc
here is what the water line is wrapped in so it makes easier to see what im talkin about
Old 04-09-2013 | 08:15 PM
baka1969's Avatar
baka1969
That is a great idea. Something to ponder.
Old 04-09-2013 | 08:21 PM
Harleycruiser's Avatar
Harleycruiser
cut the ends off
instant cables
Dude You are a handy guy yourself, love that idea.
Old 04-09-2013 | 08:51 PM
elfnyc's Avatar
elfnyc
thanks .....
tryin to help save you guys some money
ps the braided lines work like those chinese finger lock toys --
they scrunch up an get bigger - when tugged on they shrink in size
Quick Reply: Wire wrap?
