DK custom lift with my bike?
04-07-2013, 09:58 PM
Looking into doing a 1.5 or 2 inch lift, but seems like it's going to hit the speedo. Anyone do one with a speedo mounted like this?
04-07-2013, 10:19 PM
04-07-2013, 10:32 PM
Is turning the clamp and risers 180Degrees an option so the speedo sits on top?
04-07-2013, 10:33 PM
I like that setup you have. Thanks for the info.
04-07-2013, 11:59 PM
Quote:
Originally Posted by
Jolia
It is very close, and depending on how HD made Your Custom (they have a rather large leeway in their tolerances) you may be able to fit a 1.5" Tank Lift.
Here's a link with some easy steps on how to check.
https://www.hdforums.com/forum/vendo...ed-weekly.html
04-08-2013, 12:12 AM
Get a longer set of risers or a riser extensions Both sold from DK customs. More clearance for the speedo.
04-08-2013, 01:43 AM
Twiste
Unfortunately the Custom uses a completely different riser set up...ours won't work with the Custom, and the few that are out there are pretty high $.
04-08-2013, 12:41 PM
$eventy2T
No. The speedo housing is notched, so to speak, so your speedo would be upside down. I also don't think the bolt holes would line up.
WightDiamond
09-29-2018 10:44 AM
hobo1
07-02-2012 04:50 PM
hobo1
05-10-2012 06:37 PM
heloman29
02-15-2012 12:04 PM
ALPHA MALE
02-20-2007 12:16 PM
