883 poor gas mileage
04-03-2013, 12:30 PM
Greetings.
I recently started riding a 2007 sportster XL883L. I love it except for bad gas mileage. I use it primarily to commute 30 miles each way on the freeway, 65mph. I've been averaging 38mpg. Is this normal or should I be trouble shooting for a cause?
04-03-2013, 12:33 PM
I would start looking for a problem. Could be crappy winter fuel. I know my wife's 2008 883 gets around 48-50 mpg on the interstate at 65 mph. You should be doing better then 38.
Sounds a bit much. That's just a little more than I do on my ultra.
04-03-2013, 12:44 PM
Glad to know I can get better mpg. Any suggestions of things to check?
thanks
04-03-2013, 12:55 PM
04-03-2013, 12:56 PM
air cleaner, tire pressure, a/f ratio
04-03-2013, 12:58 PM
what mods have been done to the bike and what tuner is on it?
04-03-2013, 01:08 PM
To my knowledge no mods or tuning have been done. I will double check with previous owner.
The air cleaner is clean, the tires are at recommended pressure, I don't know how to check a/f ratio.
04-03-2013, 01:48 PM
You can pull a spark plug and check if it's running rich. When was the last time the oil was changed?
04-03-2013, 02:00 PM
check your cycl head temp sensor and with the above suggestions...
tire pres, AFR, plugs, airfilter, exhaust... ect
