Back brake light only pulling .5 volts. Any suggestions?
Check the voltage at the connector at the taillight. If there is 12 volts there it is most likely the ground or the bulb is not making good contact with the holder. If the voltage is low at the connector then there is a bad connection further up stream, check voltage at connectors upstream until you find the problem.
Good luck
Good luck
lost_in_calgary
11-12-2013 08:50 PM
