75 mph wobble NEED HELP!!!
Old 03-24-2013 | 05:41 PM
Sikdvlz's Avatar
Sikdvlz
Default 75 mph wobble NEED HELP!!!
New tires on this weekend. Have triple checked everything I could think of, tire direction correct, everything tight. Wheel is aligned as best to my ability. Any input on what would cause it to feel smooth and straight till I get up to around 75 mph then it started wobbling (straight away not through curves). An using dyna balancing beads instead of conventional weights.
Old 03-24-2013 | 05:46 PM
cHarley's Avatar
cHarley
Have you checked the Fall Away adjustment?
Old 03-24-2013 | 05:51 PM
Madnss's Avatar
Madnss
Plus 1 on that!
Sikdvlz's Avatar
Sikdvlz
I don't know what that is let alone how to adjust it. The wobble felt so bad that I'm not sure if it was coming from the rear or the front
Old 03-24-2013 | 05:52 PM
Sikdvlz's Avatar
Sikdvlz
I'm running a 2010 Sportster 1200 Custom.
Old 03-24-2013 | 05:54 PM
Madnss's Avatar
Madnss
The bearings in the neck, need to tighten up or replace.
Old 03-24-2013 | 07:41 PM
Sikdvlz's Avatar
Sikdvlz
Could this be just bad alignment or out of balanced tires?
Old 03-24-2013 | 07:53 PM
Curt1953's Avatar
Curt1953
Yes it could be out of balanced, who put the tire on, didn't they balance it. At 1:10 in this video shows you how to check the fall away.
Old 03-24-2013 | 08:21 PM
John_K's Avatar
John_K
Drain the OEM swill from the forks and put in equal, and proper amount of BelRay 10wt and your problem will magically go away.
(ask me how I know)
Old 03-24-2013 | 08:47 PM
Sikdvlz's Avatar
Sikdvlz
I change the tires my self but I decided to use dyna balancing beads. Which I be gaining to think are my problem.
Quick Reply: 75 mph wobble NEED HELP!!!
