Handlebar suggestions
03-24-2013, 05:14 PM
rickss69 - What year/model Sporty did that start out as?
03-24-2013, 05:23 PM
Quote:
Originally Posted by
YellaSport
2007 883L -
03-24-2013, 05:52 PM
The bars are 56079-93t
Tip to Tip = 32.00
Base Width = 10.00
Rise (Inside) = 10.25
Pull Back = 6.50
Knurl Center to Center = 3.14
Rise (Tip-to-Base) (Outside) = 8.75
03-25-2013, 08:24 AM
skyflyer
Tip to Tip = 32.00
Base Width = 10.00
Pull Back = 6.50
Thanks man
03-25-2013, 12:08 PM
I just put 8" Biltwell Chumps on my bike. Excellent choice IMO. Puts your back very close to a straight position, but keeps the arms lower than apes and wind resistance down to a more reasonable level. The bike had 12" mini apes when I bought it, so my cables are about 4" long, and after buying and returning a few replacements that were still too long, I'm pretty certain stock length would have worked for these bars. Also, I think these bars go well visually with the more classic look of the low and custom series.
03-25-2013, 12:31 PM
I just added Biltwell Friscos. Definitely helps me sit up a lot better than the stock bars.
03-25-2013, 04:58 PM
I'd love to see those Chumps and Frisco's. What I appreciated most about the Biltwell bars is how light they are (coming from 14" Pudgy Grit Hangers).
03-25-2013, 06:41 PM
skyflyer
I had mini apes put on mine and love it.
I left the funky riser on so it still has the pull back.
The bike had buckhorns when I got it, the height was ok but the angle sucked. I'm 6ft. and my hands are just below shoulder height.
Keep in mind that the SuperLow (& 48) has handlebar clamp integral to the upper tree. This 1200C has a large riser.
03-26-2013, 04:35 AM
Biltwell Chumps changed my life.
07-08-2013, 09:50 AM
rickss69
Most comfortable bars I've ever had on a Sportster is a set of Santee Wide-n-Low's. Next in line would be a stock set of a Roadster.
Will the Santee Wide & Lows fit the Superlow 883 with the 4.5 gal tank? What model number are those bars in the photo? Thanks.
