Help, shock install.....
Help, shock install.....(fixed)
Had a 8:30 service appointment to get my Progressive 444's put on, was raining like cats and dogs until about 11:00. Got to looking at the shocks and figured I'd just do it myself. FYI, not real mechanical however I can usually figure stuff out as long as its fairly basic.....
Went and got a T50, took of the left shock pretty easy. Installed the left 444 and the top bolt would only go in about a half inch. Pulled it out and took a look at it and it seemed that there was some thread lock on the bolt, chipped away at it and the bolt still will not go in.
Is there thread lock inside the place where the bolt goes in? I took a flash light and can't really see anything.......did I strip the inside somehow taking the top bolt off? It came out pretty easy.
What the hell do I do now?
All suggestions welcome.
RJ
RJ
Would a tap work to help clean everything out?
The threads inside the eyelet of the shock shouldn't have threadlock on them. Did you take a flashlight to see of the threads were clear?
Maybe you put the shock on backwards?
Yes, what they said, jack up, apply new thread lock, etc. HOWEVER! are you using the same bolts? Maybe the new one's are metric or something, I don't think threadlock would be tough enough to preventing you from starting a new thread. Try these bolts and nuts without the shock to see if they are the same thread!
Using the same bolts, bolt is fine, I can screw on a nut with no problem. The problem is in the bolt hole. Something is in there preventing the bolt to screw all the way in. Looking with a flashlight isn't much help.
I think I'm going to use a tap and carefully clean out the threads on the female end....
