re-programming necessary
Since you already have the tuner I'd have it tuned on a Dyno. Without a proper tune, I'd say you are running very lean since you have a high flow a/c and exhaust. Engines don't like to run lean because they will most likely run hotter than necessary. A dyno tune will run you near $350 most likely and will add a few HP in most cases. You could also check with the manufacturer of the tuner. They may have a canned tune that is close to what you need considering your Stage I setup.
-Beer
-Beer
Sounds like the bike already had the HD stage 1 map installed when he got the SEPST from the dealer. Since you already have a good flash tuner there is no need to buy another one like the powervision. The SEPST also has a data gathering tuning feature called smart tune that adjusts the VE tables based on data it gathers during a ride from the narrow band o2 sensors. It may take more data runs because of the narrow band sensors but you will be able to fine tune your VE tables, which is one of the main goals of a dyno tune. You can also easily change your AFR map to get the motor running richer. There is a great thread here about the SEPST that has several good afr tables shown.
You should be fine running with your new AC the way it is, yes it will be running lean but probably no leaner than it does when it comes from the factory.
A dyno tune is optimal but if you are on a budget just get the sepst software and cable if you dont have them already(probably about $50) and you can do smart tune runs and adjust your map yourself. It is not hard to do and will be a fraction of the cost of the dyno tune.
There would have been no reason (other than to be dishonest) to originally have sold you the supertuner if they weren't going to do a download, and it probably got the stage 1. The dealership will only download one of the HD maps unless you're having a dyno tune done, which you didn't, so it would have likely been one of three maps included with the supertuner. I'm looking at them right now and all three of them include upgraded air cleaners and exhaust. I'd bet you're already set up and ready to go with your new air cleaner, because the dealer charges even bigger bucks for customized maps from dyno tunes. There's really no reason to download a map that is specially designed for aftermarket pipes but stock air cleaner, but there IS for having both done, so they prepared you for the future, which in your case is now.
You won't get much out of a dyno tune on this bike - maybe a few hp/tq but really, not worth it IMO.
I agree with your assessment, but there's a few things to clear up about the super tuner. SMART Tune is disabled for the Sportster ECM as a cost savings measure, and for the VROD due to complexity (definitely). The Supertuner software is several hundred dollars, and learning how to properly use it takes dedication, hard work, and a lot of trial and error. However, it is VERY rewarding. OP - if you want to go this route, you will have to buy the cables from the dealership, but some of us...hint....can get you the software if you ask nicely.
Not sure what you mean by the SMART tune being disabled for sportsters? I used the SMART Tune feature myself when I did my 1250 conversion and it worked great and was not difficult to use, that was a year ago. This was my first time tuning a efi bike and in my case I did not find it difficult to do. I just spent some time thoroughly reading the manual.
