after market tachometer
Old 03-20-2013 | 10:45 PM
VBdiver's Avatar
VBdiver
Default after market tachometer
has anyone on here with 2007+ gotten a mini tach to actually work ?
I have been through 3 installs / un-installs with one from a well known after market advertiser on here whom I will not name because I don't want say anything negative about because they have a good return policy.
the first tach I hooked exactly as the instructions & it registered maybe half of the actual rpm's . I called the vendor & customer service said I needed an adapter that was not listed on there web page . It was actually listed on their competitors ( huh !)
I get the adapter a week later, hook it up as the instructions & guess what ? I got nothing , it does the self check needle swing to max & back , then nothing with motor running .
Get a return authorization , go to UPS , wait another couple of weeks , get another Tach and another adapter ( 2 different mfrs mind you ) .
This time I have a good friend with 30+ year experience Harley mechanic with multiple levels of just about every certification one could have , hook it up . Guess what ? Same thing ...... nada .
any way , not like I didn't try , but after 3 installs & un installs i'm over it ..... big time !
guess i'll have to bite the bullet & buy the $300 HD combo Tach/Speedometer . sounds like that will work with the biggest b- tch being an additional part to make the fuel gauge work .
I have absolutley NO interest in that Speedway blue light digital whatchamacallit . it's a swinging needle or nothing .
So if anyone on here actually has on working on an EFI , please post a video & show me one working & how they hooked up there's up .
sorry if this was long winded & i'm sure someone want's to blast " did you use the search forum tool ?" . well yes i did , on multiple HD pages .
In fact ,I may post this msg on one of the other forums .
Maybe someone has had as much fun with this as I .
thanks
Old 03-21-2013 | 12:06 AM
ev0lution7's Avatar
ev0lution7
I've gotta say after owning the Dakota Digital BLUE tach its grows on you and the features it gives you are AWESOME!!!
i Would check out the dakota first before you totally write it off... IMO it looks pretty good i get ALOT of complements on how it looks factory!
Old 03-21-2013 | 01:00 AM
xxINKxx's Avatar
xxINKxx
Do you really need a tach? Just listen to the sound of the motor.
Old 03-21-2013 | 09:34 AM
VBdiver's Avatar
VBdiver
need or want ? it would be nice to have for tuning , the only RPM i'm certain of , is the rev limiter . My ears aren't that accurate .
Old 03-21-2013 | 12:01 PM
xxINKxx's Avatar
xxINKxx
That makes sense. Alot of people want one just for cruising around the city and drop big money on gauges and go through issues too.
What about those small ones on eBay? They are like 60$. I think I've read good reviews. As long as you hook it up to the correct wire (negative tach signal wire for EFI)
http://item.mobileweb.ebay.com/viewi...id=25043711383
http://www.tachsforharleys.com/
Old 03-21-2013 | 06:56 PM
Roni's Avatar
Roni
I have the HD combo unit on mine. It was a bit of a PITA to install the sensor in the gas tank: seemed more like art than science. All the same, I really like the unit. (Unlike other folks on here, a bike just doesn't feel right without a tach.)
Old 03-21-2013 | 08:37 PM
Madnss's Avatar
Madnss
Just double check you have a good ground. That will mess up everything. I run an autometer tach. It is extremely accurate.
dpoll995
08-28-2015 11:41 PM
Sanyasi
01-12-2014 01:16 AM
NumberingRavens
09-26-2007 10:54 PM
bdavis
03-18-2007 05:49 AM
Slash
12-09-2006 09:27 PM
Quick Reply: after market tachometer
