help with rear turn signal wiring with side mount taillight
Old 03-07-2013 | 09:46 PM
section8joe's Avatar
section8joe
Default help with rear turn signal wiring with side mount taillight
I'm going to be making a side mount plate with taillight for my girlfriends 2005 sporty. I was looking through the service manual and I see that the rear turn signals plug into the taillight. If I remove the stock taillight what is the best way to wire up the turn signals. I tried searching but I'm not getting much luck. I'm sure this isn't the first time this question has been asked. Thanks in advance.
Old 03-08-2013 | 06:16 AM
nc883's Avatar
nc883
The "plug in" on the stock tail lamp on my 02 was a simple little circuit board of sorts, removable from the tail lamp. I extended my signal wire and brake lamp harnesses so that the circuit board is mounted under the seat. Used the factory connectors as well. Nice and clean IMO
Old 03-08-2013 | 10:25 AM
DallasSportster's Avatar
DallasSportster
I chopped my fender and deleted the tail light. I also added a side mount plate with only a plate light. Check your wiring diagrams. I deleted the circuit board and wired the turn signals directly. I believe it was a purple and black wire that goes to each. I tapped into the plate light wire under my seat. I also plugged in a run/turn/brake module which is what I tapped in to in order to keep the factory harness untouched. Adding a side mount tail light just just involve a couple more wires. I ran my plate light wire under the swingarm and up underneath the seat. Good luck!
joshag
04-15-2018 06:10 AM
albanynyharleyrider
04-04-2010 07:46 PM
HD32
Electrical/Lighting/Alarm
03-10-2009 06:17 PM
HD32
02-12-2009 03:27 PM
canuk cruiser
04-19-2006 12:58 AM
