What is everyone using for their tranny/primary oil. Do anyone use the 75/140 and is it better. Just read a million posts on oil and its mind bogling. So what do I do, start another post.
The 75-140 viscosity oils are for use in the Big Twin trannys where they have a separate oil supply for the primary and tranny. For the Sporty which has a shared primary and tranny, you want to stay with a 75-90 viscosity Gear Oil.
try red line syn gear lube in the tranny. its pink in color so if you drain the
primary & you see any pink at all you know you have a leaking seal between the tranny & primary.
Factory primary fluid works just fine in my 100 hp street stip bike, even after hot lapping at the track on 90* days. I had trouble when I tried switching. Any reason the factory fluid isn't good enough, I'd like to know why. You can be asking for trouble when changing. Factory fluid works fine with after market clutches too. Period
