Just bought 2009 Nightster. Some questions.
Old 03-03-2013, 01:01 PM
lovecheese45's Avatar
lovecheese45
lovecheese45 is offline
It is currently 36 here. Should I jump on it and hold the throttle open giving it just enough gas to warm up?
When I test drove it, it was roughly 40 degrees and it started up just fine.
  #32
Old 03-03-2013, 01:07 PM
Brion B's Avatar
Brion B
Brion B is offline
36 is cold enough for it to stall when cold.It should idle on its own after starting and stalling a couple of times.A set of xied's (fuel enricher) or a tuner will solve this problem.Harley has the bikes way too lean in the stock form.
  #33
Old 03-03-2013, 01:10 PM
lovecheese45
Thanks! I'll go back out after I finish eating and try it again. This time I'll sit on it and let it idle a little higher for a minute or two. Then see if it stalls.
  #34
Old 03-03-2013, 01:13 PM
Brion B's Avatar
Brion B
Brion B is offline
If you have any questions send me a private message and I will give you my cell number if you want.
  #35
Old 03-03-2013, 01:37 PM
lovecheese45
It stalled when giving it gas too. I bet the lines have gummed up since it's old gas.
  #36
Old 03-03-2013, 01:43 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
your just gonna drain that battery again with a combination of starting a lot without running and the cold temps it will die quick. if you are not really mechanically inclined it might be time to seek professional help. to continue to try and run it with old gas isn't gonna improve the way it runs.
  #37
Old 03-03-2013, 09:39 PM
lovecheese45
Thanks to Brion calling, I got everything situated! Had it running for 10-15 minutes idling without any problems. Instead of taking it to Harley, I'm going to use that money towards a tuner and get rid of the running lean problem!
Flipper1234
Sportster Parts
09-15-2023 08:27 AM
wpahole
01-14-2016 04:05 PM
luisyfz
Motorcycles For Sale
08-25-2012 10:09 AM
dank24
51
03-10-2010 11:28 PM
laostravel
Harley Davidson Videos
08-19-2008 05:33 AM
Quick Reply: Just bought 2009 Nightster. Some questions.
