Breather Bolt question
2003 sportster with stock AC cover, KN filter inside.
I have the old "sportster oil blow by" I was told that "breather bolts" the ones with the mesh filter inside would solve the problem. has anyone used them? I have seen them in pictures used "outside" the AC, has anyone used them inside?
TJ
TJ
Two things, run your oil level down to the lower end of normal, two, don't lug the motor. Sportsters hate this, run her hard. As for the bolts you are referring to, if I understand what you are talking about, you would need to change the breather for them to fit, or at least modify it a bit.
Zimbob is correct, the breather bolts won't work with stock filter without some modification.
Also, per your manual, the oil level should be in between the lower and higher mark, and should be the correct viscosity.
https://www.hdforums.com/forum/oil-r...oil-level.html
If you are doing all this well and still getting a lot of blow-by, then replacing the umbrella valves may be in order.
The breather bolts do not cover up some other problem with the engine (bad umbrella valves, worn rings etc.)
What you can do to prevent oil dripping and general mess on a bike that is having excessive blow by due to worn parts, is use one of these breather systems with the filter up top. CLICKY
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
The relocater kit was my next thought....thank you all for your input!
...or grab some 1/2 bolts, plug the head breathers, tap your cam cover at the round section behind the oil filter with a 1/8-27 NPT, bend you some sheet alum to make a oil barrier, throw a 1/8 M NPTF with 3/8 barb, buy a krankvent etse and be done with it. On an 03, you may even have the port already in the cam cover, i can't remember if they already did away with it then or not.
There are some threads around somewhere on how to do this. I'll be glad to help out if you want to go this route.
Last edited by Kontankerous; 02-26-2013 at 09:06 PM. Reason: totally screwed the TPI on the tap
...or grab some 1/2 bolts, plug the head breathers, tap your cam cover at the round section behind the oil filter with a 1/8-18 NPT, bend you some sheet alum to make a oil barrier, throw a 1/8 M NPTF with 3/8 barb, buy a krankvent etse and be done with it. On an 03, you may even have the port already in the cam cover, i can't remember if they already did away with it then or not.
