Had my first 60 mile ride with xied
Old 02-24-2013, 01:21 PM
IronHyena's Avatar
IronHyena
IronHyena is offline
Default Had my first 60 mile ride with xied
i think the bike ran good. pulled my pluggs and they looked kind of wite. could any of you try to look at thies pics and tell what you think? did not manage to focus good on the spark plugs. sorry for that.
http://www.flickr.com/photos/9228307...in/photostream
ther are to be 4 pics
thanks
Old 02-24-2013, 02:20 PM
BaldHOG1222's Avatar
BaldHOG1222
BaldHOG1222 is offline
If its EFI, looking at the plugs won't tell you anything.
Old 02-24-2013, 02:43 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
Why not? plugs will still show rich or lean by their color .air and fuel can be lean or rich with efi. in fact it is much leaner from the factory than it should be. the plugs in your picture actually look pretty good to me. a bit rich is much more acceptable than lean.
Old 02-24-2013, 02:45 PM
Wild Card's Avatar
Wild Card
Wild Card is offline
False stayement. Plug chop will always tell you no matter the induction method
Old 02-24-2013, 02:59 PM
IronHyena's Avatar
IronHyena
ok. thanks, then i'll have my peace of mind.
Old 02-24-2013, 03:03 PM
huntnaz's Avatar
huntnaz
huntnaz is offline
thanks
Don't look too bad! How's your Iron handling with xied?
Old 02-24-2013, 03:37 PM
IronHyena's Avatar
IronHyena
i think i got back the power i lost with just haveing the slip on's on. i had one littel ride before winter set in with the se II, and then i felt i lost power. had to use more trottle just to take of.
on this first ride with the xied, i kind of took it easy. read someting on this forum to let the bike relearn.
only thing i notised was a little popping when reaceliration from high rpm in low gear. but then again that could be when i ran stock pipes as well. i just didnt hear it then.
sorry for my english, i read and understand better then i write
Old 02-24-2013, 04:04 PM
IRON1250's Avatar
IRON1250
IRON1250 is offline
I highly recommend the thundermax if you can afford it. you won't be sorry.
Old 02-24-2013, 04:10 PM
1200Cdriver's Avatar
1200Cdriver
1200Cdriver is offline
IH, I have a Power Commander III on my 2007 1200 C, it is set 10% richer than stock and is what I consider perfect. Your plugs are exactly like mine.
Old 02-24-2013, 04:30 PM
IronHyena's Avatar
IronHyena
my plan was to ride with this setup this season, then do the 1250 kit next winterbreak.
i will surely ask for recommendation then.
BTW my ride- http://www.flickr.com/photos/9228307...ream/lightbox/
thanks alot all
Quick Reply: Had my first 60 mile ride with xied
