xeids vs tuner
xeids vs tuner
Well my long awaited tax returns have come which means its time to purchase an a/c to complete my stage 1 (already have bassani sweepers). Now I have read around about xeids or the power commander and I'm not quite sure which one would be best for me. I never plan on racing my bike or taking it to the track, I just want it to run smooth with any additional power I can get out of it. From what I've read I have come to the conclusion that the xeids would probably be best for me but what other perks come with something like the power commander?
Also where is the best place to purchase either of those?
"I just want it to run smooth with any additional power I can get out of it."
Tuner.
"From what I've read I have come to the conclusion that the xeids would probably be best for me but what other perks come with something like the power commander?"
XiED's.
[insert: sound of broken record, sorry, LOL] The two are like apples and Ferarri's; two totally different animals, one designed specifically with one and only one thing in mind - to fool your ECM into adding more fuel at a given rate, the other designed specifically to eliminate your lean factory condition, to give you better performance through proper air/fuel ratio values, maintain proper corresponding timing retard/advance at changing RPM's, smoother acceleration and deceleration, some have the ability to log data to later change to values you wish to experiment with to then reflash and road test, utilize custom MAPS for your current and/or changing engine configuration, display data on the fly, either piggy back to your ECM or flash tune like a Power Vision, to work as a tool for a tech to utilize in combination with a Dyno tune, etc. The cost and performance increase between the two reflect this reality.
Alot of people are completely satisfied with the XiED's. Alot of people are completly satisfied with their tuners. Apparently, for two different reasons!
Oh geez I wish I had a dollar every time this subject comes up - I'da had my 1250 bigbore kit installed already, hahahahahahaha!
=8^)
Tuner.
XiED's.
=8^)
when I first got the bike it had a low speed surge,everyone was talking air pipes tuner for stage 1,didn"t want to get into all that, so I put on the xieds,surge was gone bike ran better, next decieded to put a K&N stock air filter on it that gave me a little better milage and it was smoother yet,ran like that for a couple of years then got some rush slipons used cheap and put them on. bike still runs fine and still no tuner. going to change pipes next and see what happens, may have to put a tuner on maybe not
A lot of people are under the impression that tuners are overkill for a simple stage one upgrade. I ran XEID's for 6 months and the bike ran "pretty good" I had the extra cash and found out that one of the best dyno tuners were just 12 miles from my house so I made an appointment and took off my XEID's the day I drove to the tuners shop. The bike still ran "pretty good" I picked it up late that afternoon and was amazed on the way home. I was expecting to have more pep, but I wasn't expecting it to run so smooth through all the gears...It was a night and day difference...This is what it cost me:
I split the cost of a 500 TTS 2 bike tuner....$250
Total cost of dyno tune:...........................$300
$550 total
Don't go through the expense of buying a tuner that just adjust fuel..you may as well just run the XEID's. A quality tuner adjust timing and tunes each cylinder individually.
If you know you are not going to do any more engine mods and you have a well known dyno tuner you can travel to, here is another option:
With both dynovison and TTS you can buy the license fee for 150-200 and use your dynotuners tuner and potentially get it all done for around 500 bucks.
Don't go cheep on the tune....It is whats running your bike. If done right, it will be the best thing you've ever done to your bike even if you are just cruising around town.
Why wouldn't you want your bike to run the best it can? It's not about racing (well it will do that much better too) It's about the cruisability of the bike you spent a lot of money on to buy in the first place.
$550 total
+1 to Rooti.....
If you haven't already, go to the link below and watch the video on the PowerVision. Had Xied's, wasn't happy....Currently have a Fuelpak....kind of happy but not totally. Can't wait to get a PowerVision. I haven't read about one person who wasn't happy about investing in one. You can get one for around $450 online.
http://www.dynojet.com/powervision/
I have python slippons on my 11 nightster and I havdnt done anything else to it. Took it out for a ride last Saturday and only got 47 miles to a full tank I called the hd dealer and told them what I did and they asked if it had o2 sensors ... Well long story short the remaped my computer and changed the sensors and did screaming eagle stage 1 up grade ... $$489... Now that's cheap said if I don't plan on doing anything to motor that's what they recommend
Xieds do one thing: Lessen the already lean condition that gets magnified by higher flow pipes and a larger CFM A/C. It's a simple "fool" device. It's a resistor that sits midstream in the data path between O2 sensor and ECM. The whole O2 signal is based on a frequency that changes based on what the sensor picks up (to put it extremely plain and simple). The Xieds alter that frequency making the ECM "think" the system is way leaner than it's supposed to be, therefore causing it to add fuel. That's it.
Tuners (NOT piggybacks like FuelPak and other BS): They allow the opportunity to either "autotune" or based off logging, adjust the various different tables that comprise an overall "map". That map is what essentially gets replaced on your ECM. The altering of these tables is what "fine tunes" your bike giving you your "best bang for the buck" (pun kinda intended ). Yes pre-made maps are close, but each bike internals are different. So a map provided by a vendor is Ok, but realize it's a starting point. No two engines are EVER the same. Break-in, wear, and variance in tolerances all create that difference. That's why ultimately a great tuner + dyno time will get your bike an exact tip top map. I think we need a Xied vs. Tuner sticky...at some point..sheesh
