Just put in a K&N A/F, about to change exhaust, do I need to remap?
Hey guys, I just got my 1200C and put the K&N air filter on today. The noise with the stock exhaust is considerably different: lower, angrier, NICE.
I'm installing the V&H slip-ons tomorrow. So my question is: do I need remapping? Will the injection system take care of the change in air flow (in and out)?
Thanks for the help! Here's a pic for ya.
At least here in the US the bikes come from the MoCo on the lean side for emissions. So yes we would certainly recommend making adjustments to compensate for the better intake/exhaust mods. The factory unit does have a window for adjustments but it is a small window and will not be sufficient to get the bike running at an optimal level.
However, if performance is your thing a tuner of some sort should be a priority. Also, would be interesting to see if the factor ECM can adjust for pipes and intake...hmmmmmmmm...my be experiment time on the Dyna this weekend.
Location: In the foothills of southwestern NC - US of A
Yes, to obtain at least a "Stage 1.000001b" configuration with your intake and new pipes/slipons you will need to get a...nevermind, and for goodness sakes don't use the...nevermind, because if you do:
a) the angle of the dangle won't remain in direct proportion to the heat of the meat which b) causes the size of the rise and c) the mass of the *** to remain constant.
Phew, glad I got that out. Quite simple really, and nothing else is acceptable. 'Erybody knows this, 'erybody!!
Oh, nice bike!
=8^)
Oh, nice bike!
=8^)
Last edited by DrewBone; 02-06-2013 at 05:18 PM. Reason: I lyke to correkt myself uf bad spellink
I have a question about this also. I know my man robo knows his stuff so I hope he can explain. I have a 1200L. I put cycle shacks and the SE heavy breather on. I had no noticeable problems. But was told by many you have to get the HD download for the EFU to allow more fuel. So I got it done. Two months later started getting decel popping going back to second gear. I purchased and installed the x14ied and no more popping. My question being is what does the factory download accomplish. I read on the night rider sight that the download is not needed and its an old school frame of mind. And that the download just changes rpm nothing with AFM.
