Iron 883 drag bars
Old 02-06-2013 | 09:54 AM
Stonetone's Avatar
Stonetone
Default Iron 883 drag bars
I'm looking for a comfortable pair of drag bars for my bike. I'm only 5'7", so I don't have really long arms. The stock handlebars are just fine, length-wise. Can anyone suggest a good drag bar that is around that length?
Old 02-06-2013 | 01:23 PM
edgeofinsanity's Avatar
edgeofinsanity
I went through several bars before finding some I liked. One thing with the drag bars I noticed, since they don't have as much pullback, you can go a little more narrow and still need the same amount of reach, if that makes sense.
I found the Biltwell bars to be about as good as anything, and I would suggest these, figuring you want black:
http://www.biltwellinc.com/index.php...t_detail&p=230
FWIW I ended up with the Biltwell Tracker bars, kind of an "in between" of drag bars and the stock bars.
Make sure you have clearance with your tank, I have a riser so I didn't have issues, but it was close on my turn signals.
Old 02-06-2013 | 01:44 PM
aqcr_28's Avatar
aqcr_28
HD has their own set of drag bars that are the same width as the stock bars. 32" wide, 0 rise, 4" pull back.
I'm currently running the HD ones and am thinking bout shortening them down to around 30". It really all boils down to your preference for comfort and style.
Old 02-06-2013 | 02:34 PM
metalhead0215's Avatar
metalhead0215
I have Flanders 28" wide 4" pullback on my Nightster. At 5'10" its pretty comfy for me. I run the stock risers with no tank clearance issues (3.3 gal).
Old 02-06-2013 | 09:25 PM
fox4's Avatar
fox4
I just got a set of 28" wide with 4" of pullback drags in black off amazon for around $40 shipped. This is the narrowest you can run on the stock riser without hitting the tank in my experience.
Old 02-05-2015 | 06:54 PM
mox4's Avatar
mox4
4th Gear
Default drag bars
I was thinking about getting the HD drag bars for my 2014 iron 883 and I know the dealership said when changing bars that cables might need to be changed an such. Would the stock cable lengths work with the drag bar?
james4b
03-15-2015 10:16 AM
brucepancake
12-09-2014 03:23 PM
odie-in-az
07-19-2011 12:34 AM
SauceNJ
09-07-2010 08:33 AM
SkullGirl
03-24-2010 03:22 PM
Quick Reply: Iron 883 drag bars
