Polishing Aluminum?
As other stated, get yourself some paint remover/stripper to remove the clear. Then wet sand any spots you want to cleanup going with progressively finer sandpaper, and then hit with the polishing wheel & polishing rouge(sp?), which you can get a Lowe's.
Most of the polished aluminum on Harleys is clear coated and the aluminum tarnishes under the coating. Take some wax or polish and if it comes off the color of the wax then it is cleared. If it comes off black then it is not cleared.
If it is cleared then you need to strip the clear.
For me, there is nothing like the look of polished aluminum, better than chrome. I use SemiChrome in a tube, a little goes a long way and keep the rags for the next time. Basically you rotate a new rag in, bump the various grades of thick and black down and throw away only the worst one.
If you live in a cool moist winter climate, be prepared to maintain the polish as the aluminum will draw moisture and the moisture will leave white spots that turn to black onthe surface. Never spray a protectant with silicone as it will draw moisture. I used WD-40 (Water Displacing Formula 40) for extended layups in winter
your choice, how close is the area you want to polish to paint, chrome, or something else you want to protect. I used to tear down my shovel in the winter just to polish the rocker boxes real good. What are you wanting to polish? rocker boxes come off really easy, and you would have your best opportunity to strip all the clear off before polishing. And you could sit in your favorite chair, in front of the TV, with your 'ol lady bringing you a drink every now and then
Alu Polish
As I was checking out the post on polishing the alu, I noticed you have a similar exhaust system as the one I am enquiring about. Sorry for hijacking this post but can you please advise what exhaust system you have on your bike? See my new thread "What exhaust is this"
Thanks
Harry
Thanks
Harry
Thanks
Harry
Thanks
Harry
Harry, I already replied, you have a stock exhaust with the stock x-Over and the ends of the pipes have been angle cut to look like drag pipes
Yes, your aluminum is/was coated. Your polish probably wore through the clear after using it the dozen times, and finally allowed you to "polish" the aluminum.
-Beer
