Suspension confusion
I'm having trouble understanding shocks. I have a 09 XL1200L. Stock shocks and springs. Can someone explain the preload settings as far as what number setting does what. It is set at 5 which I believe is the stiffest. I am 6'0 210 and bottom out on some minor pot holes. What setting could I try. I have read a bit about buying better shocks. But what size? Sorry for the basic question here. Trying to learn as much possible being a fairly new rider. I also bought the manual and see how to change settings. Just don't get what does what. Thanks and be safe.
Sorry to say, the best adjustment for stock shocks on a sporty is to replace them.
Take-off HD Touring air shocks can be had on ebay for around $100, and they ride very nice, regardless of your weight.
__________________
TRICK!?!? From Harley- See Here
OR
TREAT from DK Custom Products ~ 10% Flash Savings on All Air Cleaners, use Code: Clean10
DKCustomProducts.com
OR
There are a lot of options out there, but the more you spend the better the shocks. What makes the most difference is the quality of the damping. HDF sponsor Howard at Motorcycle Metal custom builds Ohlins and JRI and is well worth phoning. Tell him you are a member of HDF as he offers decent discounts. Your life will never be the same again!
The take off RoadKing or StreetGlide air shocks are probably your lowest-cost option. They are adjustable somewhat by adding air. I probably have $150 total in mine with the lowering blocks and air pump.
The aftermarket shocks, like the Ohlins that grbrown is talking about will cost you quite a bit more, but will give an even better ride. I've ridden on a bike that was similar to mine that was fitted with Progressive 412s, the lowest cost Progressive shocks, which were a lot better than stock, but equal, or even a little worse riding that my air shocks. Lots of choices out there, it really comes down to what you want to spend.
You'll find that once you upgrade the rear shocks, you'll feel how bad the front forks dive and bottom out, but that's a whole different topic.
