86-90 clutch issue
86-90 clutch issue
Just picked up a 90 1200 - go through clutch adjustment process and can only ride about 5 minutes before the adjustment loosens - ideas on why? (Have done the process several times - loosen cable, counterclockwise the adjustment to resistance then back a quarter turn, reassemble the piece that locks it in place, put the cover back on with the spring, then readjust the cable) - any help is appreciated!
Thanks for the input - local stealer acts like they have never heard of this issue - kinda thinking this is old enough none of the young mechanics have had this issue before, or at least with this style of clutch setup anyway......(I will says the new style with the locknut looks much more assuring than this goofy spring retainer setup............
Have the stealer check for wobbling of your clutch basket, a common issue that can lead to destruction of your stator and rotor. Also, the magnets glued to the inside of the clutch basket can come loose.
Good luck, 1990 is a good year, last of the 4 speeds.
John
