anyone know where i can find some spiked bolts to replace the screw in the middle of the rear fender on the nightster. would also like to throw a spike where the seat mounting screw is as well if possible
It would be easy to make if you needed black ones. welding two bolts head to head and then use a bench grinder to clean up. you could do the same with stainless steal
I bought some on ebay last year. Put a strip of 3/4 inch black spikes down the frontfender and a couple on the back fender of my iron. makes it look kinda MadMax.
