Cheap alternative to HD funnels
Old 12-28-2012 | 09:57 PM
HubrisHCC's Avatar
HubrisHCC
Default Cheap alternative to HD funnels
Not sure if this is an old idea or if there are better ones out there, but I did find a pretty good alternative to purchasing the custom funnel for your oil filter and also the funnel for refilling your transmission fluid.
First of all go grab a snack. Pringles to be exact. Now with the empty can cut it longways to where you should have one piece at about 2/3 of the can.
Now pull off the piece of metal at the bottom and stuff it in under your oil filter. There will be a rib on the engine that will keep you from putting it in all the way so simply look where its hitting and cut a notch. Don't cut it to deep or oil will find its way through there and down where you dont want it.
The pictures kinda tell ya the rest of the story.
Okay now to that smaller piece of your snack can. Same basic concept pretty simple just trim to fit. Just make sure to trim the mouth of the can this time because the lip comes in handy. I just left the metal on this piece for support.
It will take two hands to fill the transmission. so you'll have to set down your beer.
Well I hope this can useful to someone.
Old 12-28-2012 | 10:02 PM
Iceman24's Avatar
Iceman24
Great idea & probably works good on a Sportster, but touring bikes have alot more in the way so a rigid tube's not going to cut it.
Old 12-28-2012 | 10:48 PM
JeffJA's Avatar
JeffJA
Nice!
Old 12-29-2012 | 10:04 AM
grbrown's Avatar
grbrown
Great stuff! I have an old Evo Glide with oil bag and have been using the cardboard tube out of a kitchen tissues roll for guiding the oil and drain plug into a can.
Old 12-29-2012 | 10:40 AM
hhkiwi's Avatar
hhkiwi
That's thinking out of the box - literally. Great idea!
Old 12-29-2012 | 12:56 PM
883Frankenbike's Avatar
883Frankenbike
I like it!!! Next oil change is going Pringles. thanks !!!
Old 12-29-2012 | 01:19 PM
millzog's Avatar
millzog
Big Kahuna HDF Member
You can snack while changing oil ........ awesome idea !!!
Shanebo
03-15-2017 07:33 PM
Rog48
Oil Archive (no new posts)
09-24-2011 03:32 AM
niterider985
07-25-2010 12:21 PM
Quick Reply: Cheap alternative to HD funnels
