Passenger peg brackets
Has anybody here removed their stock ones and put on the chrome ones? I can't get the damn screws to budge.[sm=headbang.gif] Anybody have any bright ideas? May be time for a he-man contest again!(Last time, there was red loc-tite on the damn thing. Heat didn't even work!)
RE: Passenger peg brackets
I just removed the ones from the wifes '07 1200L, because she didn't want to be in the position where someone may ask for a ride. I am going to assume the are mounted the same on the '06 and '07. I just used a hex bit socket on a ratchet. They were on pretty good, but they came off. I don't recall seeing any loc tite residue on the bolts, though. If you are having difficulty, I would recommend using a hex bit socket with a breaker bar, or an allen wrench with a pipe over it for leverage.
[align=left] [/align]
They're like the allen head bolts on the auxiliary light clamps: so damn tight I mayhaveto drill them out[:@]. I tried to get those things to turn (the ones on the right side did), but I can feel the hex starting to strip. Hope you get yours out without too much more difficulty.[&:]
ORIGINAL: outdoorgirl57
Thanks for the feedback. I guess if I'm gonna keep adding' stuff to this bike, I better invest in a hex socket set. Harley must be tired of jokes about parts falling off of the bikes! Sure isn't gonna happen now![:@]
ORIGINAL: djohnston
If you have to remove any torx bolts, replace them with allen-head bolts!!! [sm=goodidea.gif]
They ARE allen-head bolts! And with regular "L" shaped allen wrenches...I can'tget them to budge![sm=headbang.gif] (and there are 4 to get out...one is beside the pipes!) I looked at Lowe's for a socket/wrench set that had hex bits...but none were large enough for my bolts. Going to take it to a friend's next weekend and let the guys try.
ORIGINAL: djohnston
Do you have a Sears nearby? I like to buy my tools there. If not, I would try the local hardware store.
