Drag racing Pics, time sheets, vids
Hope this makes sense.
If not I'm sure if the ask one of the Administrators of the site they can be of help.
1992 xl 883. Bottom end, primary and secondary gearing all stock, stock lifters, rollers, suspension. Bike has a tach, drag bars and a front stap when I race.
Engine has buell heads ported with matching 1250 clylinder and piston kit. 575 chicken cams ,42 mikuni, Daytona twin tech ignition. Thunderheader or Sampson or pro stock pipe was on it this year. Energy one clutch as well as many passes on the factory clutch and spring. No bars, no air shift. Just over 220lbs suited at the track. Pump gas, 10.5 piston kit with a 9.1 to 1 corrected compression ratio with the chicken cams.
I'm looking to ditch the heavy azz rear wheel this winter and give a 45 mik a try.
And maybe some shocks that don't bottom out the first two feet at the track.
The bike was also tuned by me at the dyno shop, they ran the bike, i turned the wrenches, I believe with a great tuner the bike could pull a little bit more power. The shop that did my heads is about 24 hours away, so I never did make it to have them tune it.
Here is the thunderheader dyno sheet
Here is the sampson
here is the r and b
