Ride-On tire Balancer and Sealant
Hey fellas... I am re-posting this information from Olongapo1 forum member on the Sloptail side:
I've just tested a new product. Ride-On Tire Balancer and Sealant. This is a liquid product you inject into your motorcycle tire through the valve stem. Once installed, it Dynamically balances your tires as you ride, and keeps the tire balanced for the life of the tire regardless of tire wear. Additionally it also acts as a tire sealant in case of a puncture.
Previous products such as Green Slime tire sealant, were problematic as tires could not be balanced once the product was installed.
I recently mounted a new tire on the rear of my Fatboy and installed this product. Ride-On for motorcycle tires is sold in an 8 ounce bottle. My tire size required 9 ounces and I had to open a second bottle however the leftover product in the bottle will remain usable. The manufacturer warns that vibration may be felt for the first 2 or 3 miles until the product is spread through the tire from centrifugal forces. I did not experience this. Rode the bike Sunday, speeds up to 80 mph completely vibration free. I can attest that the balancing properties of this product work. I'm not going to punch holes in my new tire to test the sealing properties but there are many YouTube videos demonstrating this feature. One video is of a bullet shot into a tire which sealed itself.
I purchased Ride-On through JP Cycles. A little pricy at 15 dollars a bottle but in my opinion worth the cost. For a little over 30 buck per bike, I can ride with balanced tires and not worry about roadside flat tire repairs.
Check out the link.
http://www.ride-on.com/motorcycle-formula-mot.html
Check out the link.
It doesn't effect or corrode the wheels in any way? Aside from the sealant does anyone know how it would compare to Dyna Beads?
