Remove case to replace clutch cable? '82
If it's the screw I think you are talking about, it is just the oil level check screw. It doesn't need to be removed to take the primary cover off. You will have to drain the primary oil, take off the left footpeg mount, shift lever, and slack off the primary chain tensioner, though. Nothing should fall out when you pull the cover, but make sure the 3 steel ***** don't fall out of the clutch activator ramp. If you have a shop manual, be sure to look at it again before you start.
Allen PapaLanky Eirich
09-15-2018 06:24 PM
kjr2492
04-02-2011 08:43 PM
