Changing handlebars, need help
Old 11-09-2012 | 08:35 PM
A Rdnek's Avatar
A Rdnek
Default Changing handlebars, need help
I started changing my handlebars this afternoon and ran into a little trouble. When taking the old bars off, these 2 flanged washers fell out and I can't find where they go. A couple pictures attached.
Thanks, all help apperiacted.
Rn
Attached Thumbnails Changing handlebars, need help-dscn9253.jpg   Changing handlebars, need help-dscn9261.jpg
Old 11-09-2012 | 08:40 PM
rooti's Avatar
rooti
I believe those go on top of the rubber bushings
Old 11-10-2012 | 06:24 AM
nc883's Avatar
nc883
Yep, that's right. They push down into the riser bolt bushings, directly under the risers.
Old 11-10-2012 | 10:06 AM
A Rdnek's Avatar
A Rdnek
But I didn't take it apart that far. All I took off was the speedo and warning light bracket, and the top clamp that hold the handlebars down.
Rn
Old 11-10-2012 | 10:30 AM
nc883's Avatar
nc883
Then it has to be a "sleeve" or "shim" for the riser bolts, either at the top or bottom of your clamp.
Old 11-10-2012 | 10:42 AM
A Rdnek's Avatar
A Rdnek
YUP! Got it. They go go between the speedo bracket and the clamp. After a very close inspection I can see a little machined relief on the top of the clamp (under the speedo backet) that the flanged washers fit into.
Thank You
Ron
Old 11-10-2012 | 10:49 AM
nc883's Avatar
nc883
Glad to help. You tired of that slight vibration your bars had?
Old 11-10-2012 | 11:38 AM
HDCustomFabrication's Avatar
HDCustomFabrication
Just for future reference on stuff like this, if you don't have a parts manual with exploded views, you can look yours up here and see where everything goes.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old 11-10-2012 | 05:34 PM
A Rdnek's Avatar
A Rdnek
Oh yeah, Got the mini apes on, did not have to lengthen any cables, just reroute the throttle cables, and the clutch cable is a little tight on full left steering lock, and I am going to get a little bit longer front brake line. This one is a little tight, I am not going to try to reshape it.
Got out for a short ride and I swear I don't think it vibrates as bad as those buck horns did. I also replaced the foam Harley grips with Kuryakyn premium ISO grips. That was the most expensive part of this whole conversion. But they do feel very nice.
I bought my stuff from J&P, I bought their $47.00 9in mini Apes. It did not show knurled centers in the photo but I was very glad to see that they do have knurled centers. Worked great.
The only things that went wrong is I didn't get the throttle cables adjusted just right and I do not have full throttle, but close, and I don't have any brake light on front or rear brake. First thing I am going to check is the bulb.
Rn
Old 11-10-2012 | 05:41 PM
A Rdnek's Avatar
A Rdnek
Thank You very much for that. What a great reference.
I bookmarked this right away.
I already found what I need for my "MISSING", throttle tensioner.
Thumb screw, spring and washer.
Rn
Quick Reply: Changing handlebars, need help
