Running rich, bike seems to run fine though...
I just bought my 06 XL1200C and I've noticed a little bit of smoke at red lights (can't tell where it's coming from). It also makes me smell like gasoline after riding way more so than any other bike I've had and puts off some strong fumes. I pulled the plugs and sure enough they're black and sooty. The bike has SEII pipes (with stock baffles) and the Screamin Eagle high flow air cleaner (the one that looks like the stock ham can). The AC smells like gasoline too. No clue what jets the previous owner has in it just yet.
The bike runs like a raped ape with no popping, backfiring, farting, etc. The only annoyance is the fumes smell and mild smoke at red lights. If I don't have my FF helmet on, it actually burns my eyes and nose when stopped. Since it seems to be running well, do I leave it alone or try to lean it out? Being lazy, is there a better flowing AC that I could easily swap to, to lean it? Thanks all.
That's what I planned on unless I can get more air in somehow. I'm wondering if anyone can tell me if there is an AC that flows better than what I have now. That seems like an easy way to balance out, plus I'm not a fan of the ham-can look. I just don't know if that's realistic since I already have a "high-flow" AC.
Inspect all your fuel lines to see if there are any cracks and that all clamps are secure (hoses should not be able to spin on connectors). If they are OK then, take the gas cap to someplace that does smog checks or an auto parts store and see if they can check your tanks cap. Check and see if the line that comes from that vent where your gas cap is is connected, in good shape and goes to that round canister down at the bottom of the bike, about center between wheels. You should not be burning so rich that YOU actually smell like gas at the end of the day or so much that your eye will burn when not wearing (or wearing a half) helmet.
