I'm pretty sure clutch is shot... is this what I need?
Well, the first Harley link you listed HERE clearly says "Fits '99-later Twin Cam-equipped models and '98-'99 Evolution® 1340-equipped models".
The second Harley link you posted HERE clearly says "Fits '91-later XL models and '94-'97 Evolution® 1340-equipped models".
Don't you know what bike you have???
If I had it to do over again, I'd go with the Energy One pack. Based on many user reports, the Energy One seems to have an easier clutch lever pull and is a quality part.
WARNING: Every mile you continue ride with a failing spring plate, increases the risk of total clutch basket destruction, and that's going to be costly.
Sounds like you need to take a look. You've check primary chain too, correct?
What's the price differences between Barnett, Energy One, and Screaming Eagle? Also, with the extra friction, you may want to stick with a close to stock diaphragm spring so your clutch effort is kept reasonable. I hear a lot about the Energy One, for what it's worth.
You still need the clutch tool, what's the good and bad of those? Or are they all the same design. I heard one is more easily used than others.
John
John
AJaBra,
I believe your center clutch spring plate is gone but you will need to confirm this. The work disassembling the clutch pack is not that hard but the tool is not cheap, @ 70 USD in the US. I made my own from scrap steel it pushes the clutch spring in so the 3 legged tool is best.
Don't ride the bike much till you view the pack, the basket will get badly hurt if you run with the rivets out as they smash up the basket.
Good luck.
PS: the Barret has the pack and tool. but there is cheaper.
Good luck.
AJaBra,
Good luck.
Good luck.
