tail light on sporty 72
Hi,
According to the research, i am unable to find any luck. I am trying to figure out how to install the new custom side mount license plate taillight wirings. I've removed the rear turn signals and side mount license plate off of the fender. since it has 3 connectors under the seat which is for the left n right signals and license plate running light. how does it work with just using one tail light (license plate tail light as a brake/running light)? thanks!
chris
chris
Not sure what kind of tail light/plate mount you have, and if your plate light is in the brake and tail light. If it is you can just use one of the turn signal plugs. It has a ground, running light and brake signal wire. The brake and signal are the same wire. So every thing you need should be in one signal connector.
my bullet light came from harris specialities. it has three wires. black, red n white. I am not sure where to connect. I tried from black wire to black, red to blue and white to purple. then the running light came on but when i hit the brake it goes off (while the other connector is connected with the right side blinker). when i disconnect both blinkers and i hooked the wires as i stated earlier, nothing works.
Yes, but if you do not want that then under the seat in a connector that has 6 wires.There is a red/yellow wire it is hot only with the front or rear brakes and does not flash with the signals. This is where you would wire the brake light wire. Then wire your running light and plate light to the blue wire I mentioned earlier.
Read this thread...https://www.hdforums.com/forum/sport...un-only-3.html
