Crimping a butt connector
yes the dumbest question on this board, but i need to know.
I had to cut my front turn signal wires to relocate them to the front forks, im using those butt connectors, my first time. How many times do you crimp the butt connector? One on each end? Also the wires they just sit in there and dont have to be touching?
RE: Crimping a butt connector
If done properly, just once on each end. You will need to be sure you use the correct notch in the crimping tool for the size connector you have. They are usually color coded. The wires don't actually have to be touching each other, if that is what you mean. But obviously they need to contact the metal sleeve within the connector. Be sure you strip off the correct amount of insulation from the wire; enough so you have a good connection. But not too much so the bare wire is exposed outside of the connector. Also, make sure the crimp isn't too close to the inner or outer edge of the metal sleeve.
Good luck!
[align=left] [/align]
Good luck!
And the sleeve will make the connection, wire to wire contact is not necessary. Be sure to put the shrink wrap on first. Squeeze once if possible, two times if necessary so that when you tug (not pull) the wire it doesn't come out. If it comes out, get a new connector and do it again until you get the feel of it. Really, after you've done 2 or 3 it'll be very simple... just as long as you put the shrink wrap on before you tighten both ends. [:@] Been there.
I've used many types and brands, work in the electrical industry. Is it insulated, sized properly, long or short, well made (yes, they make cheap ones)? I'll usually crimp the entire length of metal contact area, good ones allow it and will not split,apply a dielectric jell, then apply heat shrink for a very positive, conductive and corrosion free termination.
Oh, good...glad you got some proper feedback here...I resisted respondingearlier today....
TOO many non electrical thoughts came to mind when I read the topic of the post...
"Crimping a butt connector"....OUCH!!!
Sorry....but I did resist for several hours....
It's always a struggle between good and evil around here.....
[sm=teetertooter.gif]
If you go to any GM dealer you can buy connectors that have heat shrink as the insulation and when you heat them a sealer comes out to prevent moisture from entering the connection.They are close to $2 a piece though but well worth it to avoid future electrical problems.
I wouldn't use the butt connectors that has the plastic sleeve. they make all kinds of connectors. some crimp and the outer part is shrink tube and there's the one'sthat are solder in the middle, you crimp the solder and the out is shrink tube when you heat the shrink tube it also melts the solder. that one works well. I normally solder my connections then shrink tube the connections. there is also a special crimping tool out there it cost a couplehundred dollars, they use it at the factory putting harness together. the crimp would never come apart. you just use the sleeve of a butt connector. I have access to one and it works sweet. but I wouldrecommend soldering your connectors.
im an electrician and there has been some good advise gave the only thing I would ad is if using a butt connector with the plastic sleeve and I know it is possible to get it wet alot of times I will dab silicone in the open ends of the connector to help keep out moisture.
I had a splice that was too short, and in an area so tight I couldn't use heat shrink. Then I found some "liquid heat shrink". After soldering the splice, then wrapping the connection in electrical tape, you apply this liquid and it causes a chemical reaction that melts the tape into a solid covering much like heat shrink.
I'll see how it holds up over time.
