Help on battery issue.
When I go about starting my 1200 custom, it would click and then would have no power at all, but when I go and hit my battery 3-4 times I will have power and can start the bike. Does this mean my battery is going out?
I would think the battery is starting to go but get it tested. My last battery that I just replaced had a slight hesitation on startup and then the bike would fire. When it died it was all at once. I keep my batteries on a tender every night and ride the bike daily so they get a fair amount of use but it has been a long time since I pushed a battery until it was completely dead.
Carry you bike to a battery store and have it Load tested, they can do this without taking anything apart, then start checking connections, then take a battery voltage reading with at idle, then jack the power up to 1000 rpms to check max output, you can search here there are other threads that explain checking your power output before digging in too deep.
