draining old fuel in nightster
hey guys 2008 nightster i believe or hope i only have bad fuel in the fuel tank...is their a way of draining it other than a syphon hose? I also cant get rid of the bad fuel by running it out because it wont start to run it out.......it does run when i put starting fluid in the air filter and its sat up for a while so I'm pretty sure its fuel thats where im going to start at tackling the problem at least.
yeah i can hear the fuel pump kick on....i ran it probably about 3 months ago and it cranked up fine then the tank was kinda low and i put some seafoam in it and then filled the tank up with fuel and it took me a few minutes to get started when i rode it last but after it started it ran fine...then today i went out to start it and it would crank but not fire until i put a little starting fluid in it and it kicked right off......do you think maybe i put too much sea foam in it..i would say i put about 3 ounces to about 2 gallons of gas
it has 2 gallons in it so i could add a little more...gonna see how much a syphon hose is tomarrow and might by one to syphon it out and start fresh with fresh fuel so i can at least cancel that out....i agree that the fuel shouldnt be bad but at least its something i can cancel out..... its only a few gallons.
