HELP, no light when i turn on high beam
i was riding home last nite,turned on my high beam,and every light went out,i turned on the low beam,and everything came back on,what could be the cause of this,bad switch,bad fuse,or relay ,anyone had this happen to them?its a 96 sporty if that helps
i will take it apart when i get home,just seems wierd that all lights quit,and when i flipped back to low beam,the lights came on like 15 seconds later,when i got home i tried the high beam switch 50 times and NO lights at all,each time,i will check the bulb but really doubt thats the problem.
Do you have a voltage meter on it? IF so does it fluctuate unusually when you switch to highs and all your secondary lighting goes out?
My best guess is the high beam of the bulb has become shorted and when turning it on it grounds / shorts the rest of the lighting.
It could even be in the wiring. The high beam supply wire has rubbed the frame and is grounding out.
Take out the bulb and see if the secondary go out then, when on high beams.
BTW the high / low beam switch is not directly connected to the secondary lighting. I don't thinks it the switch. But it could be where the short has developed.
