Making drag pipes work
Here is a Cheap Trick from the Old School that works if you want to run drag pipes like myself and lessen that mid rpm range drop.
www.nightrider.com/biketech/exhaust.htm
I run drag pipes with an over jet. If I had $900 plus to spare I would have R&B racing pipes on for sure.
High rpms riding makes for some good fun running drag pipes but if you dont ride that way low end is a little slow at first in fact mine acts like a bucking horse in the lower rpms.
It's not likely I will install those little do dads in my pipes I like the feel when I am at full twist around 2400 rpm. Kinda rushey.
JonMon
JonMon
High performance and drag pipes do not go together. Considering the diameter and length of drag pipes offered for Harley they would come beneficial above 12,000 RPM or so. With drag pipes you will lose in low range, in mid range and in high range (less in high range, but it's still a loss).
I did the lollipops because my bike came with drag pipes. Definitely got noticeable performance boost, but man the sound is terrible. It's now like this very high pitched whistle in the background of un-muffled sound. Definitely wanting to find slip-ons that I could put over the drag pipes (since I don't have the original exhaust).
The Sound of your bike should suite your taste and be music to your ears myself I could care less about what a dyno says both my bikes have drag pipes & they make a Harley sound like a Harley.
The 2 in 1 header will perform better but I don't like their looks or the pipes that close to the engine and to my ears they have a muffled sound.
Its all personal preference and what you like after all you have to listen to her talk lol.
Wakko47
Exhaust System Topics
06-16-2013 11:45 AM
