Who has replaced their ignition switch with a toggle?
#171
Received 2,201 Likes
Seeing those pics is giving me deja vu' or maybe they are flashbacks
Yep you got all the right parts, should look great when finished!
Remind me what connectors you are using again? I just finished painting my new speedo and it's ready to go on the bike after work today which means I will have to remove my keyless button so I can access the ACCY mode for setting up the new speedo. While I'm at it I need to clean up the wiring quite a bit so that it's not even noticeable and it sounds like what you are going to use if the way to go. Especially the water proof part!
i used these (eventually) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#173
#175
#176
got mine installed an took it out for a nice long spin - o man its so easy and works perfect - bye bye key lol thanks all for the tips and maken me spend money on it - yall suck hahaha
boring pix and a crappy video
sportster iron push button ignition - YouTube
#177
i did use the wires yes - i shorten them a bit and crimpped them to the scoots wires --- i also attached the groud wire to the allen that holds the housing so it looks clean an works
#179
#180
Yes, the connectors are just to make it quick disconnect/water proof. Using just the button I don't see how you keep ACC only.
