Anyone else have an issue with traffic lights not working for you?
So I am currently in San Antonio and today alone I had 5 traffic lights not ever work for my lane. They have sensors right? Maybe the scooter isn't heavy enough for the sensors to recognize that anyone is there? In this case what is the correct thing to do? Wait it out? As I was sitting at one light cooking away I waited for at least 5 mins with no other vehicles in the immediate area so I ran it.
Some work, some don't. It's a common problem for bikers. I try to stop the bike right over the sensors in the ground (you usually can see them). If that doesn't work after a couple cycles I usually just go straight and make a u turn. Some cops are not forgiving and will ticket you for running the red.
Also, I've heard of some bikers placing magnets on the bottom of the engine...not sure how well that works.
Stop over the top of the sensor will help with that. It is magnetic, not weight that trips the sensors. Also check if you can pass though in those situations. Here in TN, a motorcycle can run though a red light after "a reasonable amount of time" (whatever that is) if the light doesn't change.
I even have the problem sometimes on my Ultra Classic.
If you need to trigger the induction loops, weld some steel plates to the bottom.
I've pretty much given up with trying to trigger lights. Almost all of the major streets around me are timed so it's no big deal. I'm thinking there's no sensors because of the constant wind but I know which intersections that are impossible to trigger lights at so I take an alternate route to go where I'm headed. I mean, when it gets to the point where you have to dismount, hit that pedestrian trigger button and wait for the light to change, it's easier to take the long way around to get where you're going.
The induction loop triggers detect metal but it's not magnetic. Don't waste your money on those stupid magnets with zip ties that they sell as they won't work. I've tested this using even stronger magnets that I pulled from old hard drives and it doesn't do ****.
