dropped bike...fml
dropped bike...fml
Hey guys! This isn't how I wanted to introduce myself but ohh well.
I started out riding vintage motorcycles and wanted something newer/faster/nicer. I had a 1971 Honda CL175 (slow but fun).
I picked up this 2004 XL883 and love it.
I was out the other night tired and frustrated from a long day at work. I went to park the bike and tripped on the foot peg and dropped the bike on the right side (I'm still pissed and this happened a week ago). Then and there I thought the only thing that happened was a bent brake lever and hurt pride.
After eating I came to find these symptoms:
- When the bike turned on the flashers all illuminated then flashed about 6 times.
- Flashers all illuminate but wont flash.
- Brake lights don't work.
- Speedometer doesn't work.
- Speedometer doesn't light up.
- Top right fuse blown.
Things I've tried:
- Replacing fuse (it just blew right after).
- Checking wiring (I really hate electrical, I never found anything except for some questionable wiring by the previous owner.)
- Tried running a DTC code on the speedometer but nothing happened.
- Took off the back of the speedometer and unplugged and plugged in the connector and heard noises like the needle was trying to move. I did it again and the needle shakes a bit and that's it.
I'm really hoping that I can get some help here to get this all fixed without needing to go to the dealer.
Thanks!
Things I've tried:
Thanks!
Candy, if it were mine I'd start by taking a closer look at the "questionable" wiring. A low/ no speed drop like that shouldn't have any effect to mostly everything but cosmetics. If you are blowing a fuse repeatedly I'd be willing to bet you have a loose connection or something grounding out most likely around the "questionable" area. Start there wiggle connections and look for shady E-tape or after market conector jobs on the wires. Good luck man.
This was just one of those "**** happens" things for the OP. It's not some chronic issue with mid controls.
