Winterization
Winterization
This is the frist time I am going to have a bike through the winter. I had a doner bike (R6) several years ago, but I got rid of it before I had to winterize it.
Question is...what should I do to make sure my bike is safe for the winter. Obviously I will have it in the garage, but what else should I do? We have some pretty cold winters here in Indiana and I more than likely won't be riding from November till March or April.
What suggestions do you guys have? I just ordered the maintenance book from Harley and should have it in a few days. Figured I would change out the fluids before I stored it. What should I do with the fuel in the tank? What batter tender do you recommend? Anything else I should be doing?
Links would be helpful. Any suggestions will be given a chance.
Thanks!
Thanks!
I'm in Iowa so in the same boat as you for winter - hate it. This what i did winterizing my R6 before i got my harley, and it worked well.
1. Change the oil
2. Fill tank with fuel and add a stabilizer, i use Stabil. Let it run awhile to circulate
3. I pull the battery and bring it inside. Put on a battery tender, Battery Tender Junior by Deltran is a nice one.
4. Throw a cover on and say your goodbyes
I'm sure others have good ideas, but thats a good start
1. Change the oil
Thanks!
Thanks!
I too am on the northside. I work at 96th and keystone and live in the Lebanon area. Where abouts are you? Carmel, Fishers area?
1. Change the oil
1. Change the oil
As far as the battery, last year I just left it in the bike, and use this: http://www.farmandfleet.com/products...l#.UEI8LpbifAE
It came with ring connectors that I just left on the battery and a quick connect end that I can pull from under the seat and plug it in, I use it any time the battery is going to sit for a few days without riding.
Well I just bought the 'Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger' off of Amazon. Waiting on my maintenance guide....I hate thinking about winter, but I know if I don't think about it, it will be here before I know it.
DougYITBOS...I am not sure how to PM or maybe I can't yet.
