Rear Shock Length on a 72
I've been trying to look up online what the length of the rear shocks are on the 2012 SeventyTwo but to no avail. I wanna lower mine, but make sure the shocks I get are a decent length. I'm not trying to lower it so I can get my feet to the ground, just for looks. I'm 5'11" and 190 lbs
basically, I found a set of 11" Progressive 412's locally for $135. Worth it for my bike?
Thanks.
Yeah. I like em but you'll have to remove either the reflectors or the belt guard. Or both, like I did. They were hitting each other and bent em all to hell. Then again, I had them at the weakest setting at first and have since tightened them up. It definitely looks lowered but not like it would be on struts on anything. I also considered the Spitfire spring struts but I'm not sure how they'd work
This is good to know. I want to clean up the rear fender, moving the number plate carrier which would leave a sizeable gap between the fender and tyre. I also wouldn't mind better rear shocks. So progressive 11" shocks sounds like a visual and handling upgrade? Would lower the bike an inch and give better handling.
If i added a further 1" lowering block, would it bottom out on the fender?
