Trans Oil
Trans Oil
Well, its that time and I can't seem to find any videos on youtube. Does anyone have a video, pictures, or detailed step by step on how to change my trans oil?
I'm stuck on a lay over flight in Frisco and plan to do my fluids tomorrow. Thank y'all for your help, I know this is a dumb question but I've started doing all my own work instead of paying extra to go to the indy.
Dunno if this is detailed enough, but this is what I do.
Get it warm.
Park inside, or at least in the shade. lol
Pull drain plug
Pull Derby cover
Pull inspection cover
Adjust primary chain tension (replace inspection cover)
Adjust clutch
Replace drain plug, replacing o-ring if needed and using teflon tape on the threads
Fill primary with HD Formula+ until it reaches the bottom of the clutch diaphram spring.
Replace Derby cover (using blue threadlocker)
Ride!
Get it warm.
Pull drain plug
Pull Derby cover
Adjust clutch
Ride!
__________________
🚀 Grab a Chance at a $500 Refund! Click HERE! This DK Special ends 10/22/24 🏍️
DKCustomProducts.com
I have not done this yet on my new bike.
Can anyone tell me what size Torx I need for this... I don't have a Torx set yet.
I have the service manual. Was surprised to not find (or I missed it) what the size of all the fasteners were on the bike
In buying a Torx set, people warned me that it might not have all the sizes I need.
Anyone got an inventory of the Torx and other size tools I need to go basic maintenance on a Harley?
On my non-Harley bikes, I usually got a small tool kit with basic tools. No such luck with the HD Sportster 1200c
You can get a set of 13 including T27 for $16
And, by the way, this might be useful for identifying/ordering gaskets & seals which they recommend you change
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
